IR port in Vista at DVinfo.net
Open DV Discussion
Old March 25th, 2008, 08:08 AM   #1
IR port in Vista
Does anyone know how to activate the IR port in Vists? I'm trying to find where to do this but can't seem to find it. I have a laptop that has one. Thanks.
Charles
'What we perceive to be may not be what we believe to be.'
Charles King is offline   Reply With Quote
Old March 25th, 2008, 10:35 AM   #2
Which laptop is it? I have a Dell Latitude D620 and I can't even activate in on XP...
Have you checked to see if there's a BIOS setting to enable/disable it?
John Miller is offline   Reply With Quote
Old March 25th, 2008, 04:09 PM   #3
I have a HP HDX9050 The bios...I forgot about that...I'll check it out tomorrow. Thanks for the tip.
I see you have XP:
Try this:
1. Kontrolpanel
2. printer and other device
3. there is suppose to be a link that you click on..it should saything like 'cordless connection'
4. test to see if the computer's IR port works by clicking on the 'devices'
5. then click on the 'IR' tab and put a check into the box next to the 'let other devices send files to your computer's IR port...'
Try it. if it works. I have vista so I cannot verify this procedure but you can.
Charles
