Mac-based Teleprompter at DVinfo.net
Open DV Discussion
Old March 24th, 2008, 04:18 PM   #1
Anyone know of or use a Mac-Based teleprompter?
Kenn Christenson is offline   Reply With Quote
Old March 24th, 2008, 04:50 PM   #2
I like Presentation Prompter. Search for it on VersionTracker.com
Edward Carlson is offline   Reply With Quote
Old March 25th, 2008, 02:02 AM   #3
I use Presentation Prompter as well.
Solid, simple, pretty foolproof.
About the only thing I don't like is that if you want to prompt "right side out" for BOTH the prompter and the laptop, you need to buy their little VGA reverser box which is a bit expensive.
That's compared to using the hot key reverser that's built in - which allows you to make easy corrections to your script at the laptop before reversing it to prompt - but throws the display on your laptop in reverse during the actual prompting.
Still, the hardware and software are solid and mine has done hundreds of field and studio gigs with no problems.
Old March 25th, 2008, 12:18 PM   #4
An alternative may be: dvcPrompt!.
George/
George Kroonder is offline   Reply
