Archiving purpose codec at DVinfo.net
Open DV Discussion
Old February 22nd, 2008, 07:46 AM   #1
Hi everybody.
I'm trying to figure out a good codec for archiving all my footage.
Since i always store my tapes, what i want is a "what if everything goes wrong" file. Like i do with my photos. I always shoot Raw + Jpeg. If the raw file gets corrupted or lost, i always have a lower quality jpeg.
What would be the ideal format for video? Mpeg2? H264? Another format?
Remember this is only to ensure i have something if my tapes get bad.
Thanks.
L.R.
Luis Rolo is offline   Reply With Quote
Old February 22nd, 2008, 12:18 PM   #2
It sounds like size is your primary concern. With a variable bitrate and average rates around 4-6 Mbps for 720p, h.264 encoded by the x264 library is top of the class right now. The quality easily outstrips MPEG-2 at 18-24 Mbps, and even other h.264 encoders with almost twice the bitrate. The trade off is that there is a steep learning curve, the encoder settings have to be tuned just right, and it will be very slow and incompatible with Quicktime.
Daniel Browning is offline   Reply With Quote
Old February 22nd, 2008, 12:23 PM   #3
I too would use H.264, since it is an ISO standard.
Emre Safak is offline   Reply With Quote
Old February 22nd, 2008, 01:48 PM   #4
Thanks guys.
I was thinking about making the conversion with Compressor or with Final Cut's media manager, so x264 would not be an option. What should be the bit-rate for the normal h-264?
Edit: Just found a x264 installer for quicktime, so it will be compatible with compressor at least. Any suggestion on the settings?
Old February 22nd, 2008, 04:51 PM   #5
After some tests, it seems that h-264 is really the way to go. Now i just need to find a nice way of indexing and browsing all the files.
