Bouncing with reflectors - which color? at DVinfo.net
Open DV Discussion
Old January 31st, 2008, 02:37 PM   #1
Just out of curiousity
1) what is the most reflective?
2) which is the most natural?
a) White
b) Silver
c) Gold
David Delaney is offline   Reply With Quote
Old January 31st, 2008, 04:42 PM   #2
Images: 18
Hi David...................
Q1 - b, c, a
Q2 - ah, now that's a good Q.
b & c do not scatter, so will give a harder fill. c will be warmer no matter what the light source. a will give a softer less industrial look but will simply reflect (in all senses of the word) the colour temp of the incident light.
a + c should give you the best of both worlds.
CS
Old February 1st, 2008, 03:36 AM   #3
I don't like gold reflectors too much, I think the color is just too brownish-yellow. I wouldn't mind that color on skin, but when a person smiles, the teeth reflect that brownish color as well...
In some cases gold might be fine, just be careful. There are however half gold half silver reflectors - I haven't used one of them, but the concept seems promising.
Heiko Saele is offline   Reply With Quote
Old February 1st, 2008, 04:23 PM   #4
Checkerboard (half silver, half gold) reflectors do indeed end up with a pretty neutral color tone. If I had to choose one or the other I'd go with the silver as the gold is indeed usually too much unless one is trying to replicate a late afternoon golden light (pretty much only works as a hair light).
What is arguably the most natural color for bounce is unbleached muslin, which is a pale beige in color. It is also the least reflective of anything you'd be likely to bounce with so you need a lot of it.
Charles Papert
www.charlespapert.com
Old February 1st, 2008, 07:34 PM   #5
Lastolite call it sunfire.
www.lastolite.com
Ger Griffin is offline   Reply
