Any recommendations for 16:9 camera's in $3000.00 range?
I'm VERY close to purchasing my first miniDV camera, and I want to purchase one that shoots 'true' 16:9 for playback on widescreen TV's.
What is available out there in the $2,500.00-$3,300.00 range? What do you recommend and why? I will be shooting documentary type films, i.e., indoor/outdoor interviews, and using a glidecam occassionally. |
Try either the Sony FX1, V1U or Canon XH-A1. These are currently the best values in your price range.
WOW..talk about a fast response! Thank you very much. I went and posted a reply to another post, and when I came back, there was already a reply. I knew that I would like this forum when I stumbled across it this past year.
I just went and looked at them on B&H and read their specs...quite impressive. I also like the XL2 but the only drawback is that it doesn't shoot HD. But it has a host of other accolades that sets it apart from the 'pack'. I really like the feature of interchangable lens! My question...since I will be shooting documentaries, is HD really that big of a concern? Is the difference in picture quality that apparant shooting SD vs. HD on a widescreen? |
The XL2 might be worth a look if you need interchangeable lenses, but HD is becoming standard for professional work and it could be a problem to get left behind shooting widescreen SD. Resolution isn't everything, but consider that the XH-A1 records 1.5 megapixels per frame while the XL2 is only 0.3 megapixels. Also, if I remember right the XL2 has a 1/4" sensor while the XH-A1 is 1/3", giving the latter better depth of field control.
#5 |
The Canon XL2 actually has three 1/3rd-inch sensors. The full width of the sensors
is used when shooting 16:9. For more information on how it works, see my article at http://www.dvinfo.net/canonxl2/articles/article06.php There is no significant difference in depth-of-field control between 1/4" and 1/3" chips. |
#6 | |
My mistake, I see that only applies to the smaller GL2 camera. Thanks for the correction.
#7 |
Sony FX7 is more in price range, and similar to V1u and other cameras listed. Also, though I have FX1, I find that the diminutive HV20 which I also have, and that sell on street for around $ 800.00 provides a magnificent image.
Chris J. Barcellos |
#8 |
When I visited the CanonUSA site, it lists the specs for the A1 as follows:
HD: 1440 x 1080; Approx. 1.56 Megapixels SD (4:3): 1080 x 1080; Approx. 1.17 Megapixels SD (16:9): 1440 x 1080; Approx. 1.56 Megapixels Does this mean that16:9 capture can only be obtained in SD? OR....both formats (4:3 & 16:9) are captured at 1.56 MP in HD all the time? |
#9 |
HD is always 16:9. You would crop the HD image if it was intended for a 4:3 display.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese |
#10 |
#11 |
I think the XL2 is a great camera for the price. It all depends on whether you really want HD. For me, there's no point until authoring HD-DVDs becomes easier and people actually have a way to play them and HD-TVs to watch them on. Man, I would never have guessed that it would take this long but this whole conversion is moving at a glacial pace. In my neighborhood, there isn't even a venue to project HD material. Sheesh.
#12 | |
XH-A1 can shoot HDV, always 16:9, and SD in either 16:9 or 4:3 modes. The same sensor is used all the time and output downscaled for SD as needed. |
