Thread Tools
Search this Thread
Good Camera for Sports Motion Analysis
The local high school baseball coach wants a camera for motion analysis for baseball batting swings and pitching wind-up and delivery. He wants one of the cameras that record on DVD since most DVD players will playback frame-by-frame. But I also thought it would be nice to get him a camera that has some over-cranking/slo-mo features.
I've found the Sony DCR-DVD 508 and DCR-DVD 408 that will both do 240 fields-per-second, but only for a three second burst. I've found prices for this camera in the $550 to $650 range. Does anyone else know of any other cameras that will record in slo-mo that fit in this price range? |
#2 | |
The number of frames/fields per second might not be the only factor to consider. More important is often to have a short shutter time in order to "freeze" the movement. Many DV cameras have 1/1000 or shorter, but some only offer a "sports mode" Using de-interlace, dedicated software can extract 60 (or 50 in PAL-land) frames/second from a simple DV camcorder. This is often enough for sports motion analysis. /Johan |
I think that the Sony models would probably fit most of your needs. One thing to really watch however, is that regardless of what camera you get, you'll need a lot of light to make it look good. The faster the shutter goes, the less light it allows in. Don't expect good results with a high shutter speed/high framerate when you're shooting indoors. If you're outdoors with good sunlight then you'll get the results you want.
Ben |
