Voice overs in Premiere at DVinfo.net
Open DV Discussion
Old June 8th, 2003, 10:31 PM   #1
I'm doing voice overs in Premiere 6.5 by recording (in Sound Forge) to a separate computer that's networked to my video editing machine. That way, I can play from the time line while I record. Then I trim each audio clip, save it to the video computer, import it into Premiere and drop it on the time line.
This seems to be fairly efficient, but I'm wondering if there isn't a better way. Does anyone have a better method?
Paul Tauger is offline   Reply With Quote
Old June 9th, 2003, 12:18 AM   #2
Air China Pilot
Try looping
You might want to break the clip up into different sections. Then take each section, export it as an avi or easily playable format. Then have the player set on loop. That way you can just keep the video clip repeating while you try your voice over again and again.
Sound Forge shouldn't take up so many resources that you can't be looping the video at the same time.
I don't see a problem with recording on a separate machine except for having to copy over a file. You will have to drop an external file onto Premiere anyway.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old June 10th, 2003, 05:16 AM   #3
RED Code Chef
Two threads on this can be found here and here
Rob Lohman, visuar@iname.com
Old June 10th, 2003, 12:13 PM   #4
Voice Over Recording
Not the forum for this, but has anyone done voiceover using Pinnacles new Edition 5? As I read the marketing claims, it says you can do voiceover within Edition 5 while watching clip on timeline. If that is true it does something I have been told can not be done on the Premiere 6.0 I am using now (or even 6.5) without resorting to two computers or other "out of Premiere" approaches. I am considering buying Edition 5 Pro which is reason for my question on this topic of voiceover.
Dennis Hull is offline   Reply
