#16 |
Terry,
Okay... bear with me... #1) Intel is producing *massive* price drops next week. I would not purchase this system now. http://www.anandtech.com/cpuchipsets...oc.aspx?i=3038 #2) The place you are buying from is way too expensive on many items. The E6600 boxed can easily be had right now for as little as $219. #3) $150 for a 7600GT is very high, despite the passive heatsink issue. Though a video card doesn't typically have a large effect on Vegas performance, I would still recommend going with an 8' series card for DirectX 10 compatability down the line. #4) Consider buying the Antec P182 case. A place I buy 90% of my stuff from and really like is www.mwave.com Better prices than what I see here overall, great service and they have just about everything we've mentioned. Jon |
#17 |
Terry,
I ran through a similiarly configured system via the supplier I regularly use and the price is much less. #1) The Plextor SATA burners are overkill. I use the NEC drives that I attached via IDE which is works perfectly. The interface is a non-issue with DVD-R type drives and frankly, the IDE standard is looked to via the OS, etc. #2) Went with a cheaper and larger Hitachi drive that performs as well as the Seagate 7200.10's. 320Gb/ea as opposed to 250Gb. #3) Upgraded to a 8600GT video card at a cheaper price. Yes, it has a fan, but they are relatively quite and the CPU fan will be louder anyhow. #4) Went with more proven Corsair C4 memory. This memory used to cost $280 less than a year ago. Now it's half that amount and this, at the time, was some of the best memory around. #5) Went with a modular high efficiency 500-watt PS. Don't be fooled by the big number of 600 wats. 500 is *more* than plenty of what you'll ever need and likely double what your system will use even at full capacity. You are fine here, SPECIALLY with a efficient CPU like the E6600 #6) Upgarded you to Antec quite P182 monster case. #7) Gave you a better motherboard in my opinion #8) Don't buy the CPU now! Intel is releasing new CPU's at far better price points next week and the motherboard I spec'd fully supports these new 1333Mhz CPU's. Good news not only will the chips be faster, they'll be cheaper. So expect to pay about or a little less for the new chips. Looks like with shipping you can stay at or maybe under $2000.00. Insane... Jon Last edited by Jon McGuffin; July 19th, 2007 at 10:26 AM. Reason: grammar corrections |
#18 |
Hey Jon thanks alot. I have a friend who is extreamly good with computers who put that together. However, we have never built a computer designed specifically for video editing. So this is the reason behind our set up submission to DVInfo.net.
This week I will use your constructive comments to build a final computer and submit for your review. Jon you've been a great help. -Terry. |
#19 |
No problem Terry...
Another good reason to go with the 8600GT or GTS... http://www.anandtech.com/video/showdoc.aspx?i=3047 Jon |
