Simple Benchmark Premiere v6.5 vs Vegas 4.0B at DVinfo.net
Old May 1st, 2003, 01:21 PM   #1
Hi,
After reading the posts about the lack of speed in Vegas - I was curious to do a simple test myself.
I made a 1 min 5 sec long composition in both vegas and premiere. Both projects showing exactly the same, namely
1. Main video stream
2. A Photoshop PSD with alpha channel ( duration 1 min )
3. Additive dissolve to video clip nr 2
Rendering time:
Premiere 1.30
Vegas 1.42
Comments:
In my opinion Vegas does a better job with the alpha matte on the PSD. Vegas is also much faster to work with than premiere - What I miss in Vegas is full control - ie. properties->Duration isn't there and many times when Premiere lets you enter an exact number, you have to use the mouse in Vegas.
Final word:
Today Vegas is the winnner of user-friendliness and Premiere the speed winner. With Premiere 7 around the corner, sonic foundry better sharpen their knifes because I think Premiere will be a killer app!
Best regards,
Lazze Z
Sweden
Sony HDR-CX130,Canon 5DMKII,i7 930@4.0, 12gb memory, 3x SSD + 2x1Tb(stripe), Geforce 480, Dual 24", Win 7 x64
Lars Siden is offline   Reply With Quote
Old May 1st, 2003, 02:36 PM   #2
Sponsor: JET DV
Explain the "Properties - Duration" and how it is used (I don't use Premiere). It *may* be there in some fashion. I can think of at least one method (besides scripting) that could, possibly, provide that functionality if it means what it sounds like it means.
The possibility:
1. Add the clip/picture to the timeline.
2. Double-click the clip (to select it)
At this point, the timecodes immediatly below the timeline will show Selection Start, Selection End, Selection Length.
3. Double-click the Selection Length
4. Type in the desired time
5. Resize the clip to the new selection boundry
Does this do the same thing????
Old May 2nd, 2003, 03:40 AM   #3
RED Code Chef
Duration allows you to change the length of a clip whether it is
a movie (frame rate changes) or a still picture (number of frames
the still is being displayed changes)....
Rob Lohman, visuar@iname.com
Old May 2nd, 2003, 07:48 AM   #4
Sponsor: JET DV
Does my described technique do the same thing?
(note: for video, you could do it with or without framerate changing)
Old May 2nd, 2003, 07:53 AM   #5
It is as Rob says - fast way to set the duration of a still or a clip.
Edward, thanks for the tip - didn't know that I could double click the media then enter values.... the boxes are coloured as READ-only boxes - but they are editable, once again - thanks for the hint!
For me, the rendering speed disadvantage of Vegas isn't so important, I try to keep my projects at maximum 20 minutes - so the difference in redering time won't be more than 2-3 minutes... minutes that I earlier saved using Vegas faster GUI. BUT, I wouldn't cry if Vegas 4.0c or 4.1 boosted rendering
performance ;-)
// Lazze
Old May 3rd, 2003, 03:17 AM   #6
RED Code Chef
It seems to do the same thing indeed from your description,
Edward!
