Help please! New setup at DVinfo.net
Old April 6th, 2007, 10:50 AM   #1
Hi DVI Great forum!
I am putting a system together for my neighbor he is into video editing (Pinnacle Version 10) soon to be Vegas
Here are the system specs:
ASUS P5B Deluxe LGA 775 Intel P965 Express ATX Intel Motherboard
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit X 2 (4 GB total). WIN XP only sees 3GB but that will change as soon as he updates to Vista 64bit later on.
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775
Western Digital Caviar SE WD3200AAJS 320GB 7200 RPM SATA 3.0Gb/s Hard Drive X 2 (640 GB total)
XFX PVT73GUGD3 GeForce 7600GT 256MB GDDR3 PCI Express x16 Video Card
COOLER MASTER eXtreme Power RP-650-PCAR ATX from factor 12V V2.01 650W Power Supply
LG DVD- Burner
CD RW
Win XP / Sp2 32bit
Here's my question. How should I setup the Hard Drive Configuration for optimum speed while video editing and post production? Should I partition any of the drives? Should I leave one drive for OS only? Is it worth setting up a Raid Configuration? Should he add a 3rd Hard drive?
Any opinions would be appreciated. I have never built a system for Video editing before only gaming systems.
Jdegid
John Degid is offline   Reply With Quote
Old April 6th, 2007, 06:52 PM   #2
my $.02
The more hard disks the better.
Go with Windows X64 rather than Vista64 -for now run the switch in boot.ini that allows windows 32 to use the full amount of ram.b (search here or on MS's site)
I have one drive for OS and swap file, One for "currently working project" DV files, one for long term storage, one for capture, and one for scratch... about a terabyte total.
I have tried raid vs. non raid and the performance is about the same if you separate your drives decently.
You're going to get a LOT of different answers on this one.
www.facebook.com/projectspecto
Marco Wagner is offline   Reply With Quote
Old April 7th, 2007, 03:54 AM   #3
Partitioning is not helpful for editing. Physical disks are helpful as Marco said. If your friend wants to edit HDV it is good to set up a (r)aid0 configuration but he will be more susceptible to complete data loss due to disk failure. One suggestion I have is to add a WD Raptor for OS and Programs, because it is very fast and use the 7200 disks for media, scratch etc.
Old April 9th, 2007, 11:02 AM   #4
Yep,
Drive #1 = OS + Premiere Pro
Drive #2 = Capture
Drive #3 = Scratch (you can combine scratch and capture drives)
Drive #4 = Working Files
