SCSI vs SATA - Page 2 at DVinfo.net
Old December 14th, 2008, 10:39 PM   #16
Folks.
For the future tech minded , an update to this post topic ...
Serial Attached SCSI (SAS) is a data transfer technology designed to move data to and from computer storage devices such as hard drives and tape drives. It is a point-to-point serial protocol that replaces the parallel SCSI bus technology that first appeared in the mid 1980s in corporate data centers, and uses the standard SCSI command set. At present it is slightly slower than the final parallel SCSI implementation, but in 2009 it will double its present speed to 6 Gbit/s, allowing for much higher speed data transfers than previously available, and is "downwards"-compatible with second generation SATA drives. SATA 3.0 Gbit/s drives may be connected to SAS backplanes, but SAS drives may not be connected to SATA backplanes.
Read more ...
Serial Attached SCSI - Wikipedia, the free encyclopedia
Justin Hewitt is offline   Reply
