Import/Export WAV for audio editing - Is there a diff. bet. "export" and "save"?
Is there any loss in quality if you import a WAV file into Premiere, edit it -- such as to remove empty space or bad takes -- and export the file anew?
I.e. Is this a "recompression" that will cause the file to lose quality? Or is it akin to saving the file in a program specifically designed for audio editing? |
RED Code Chef
Premiere will not degrade your WAV file *IF* you don't use any
lossy WAV compression codecs. WAV files are only a vehicle. Within the WAV you still have to choose a compression format (or uncompressed)! This will decide if quality is being reduced or not. Best to work with uncompressed WAV files or lossless codecs.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
