WD ext HD turning itself off at DVinfo.net
Old February 12th, 2007, 01:39 PM   #1
I have a Western Digital external Hard Drive that keeps shutting down - sometimes after a few minutes, sometimes not at all.
When this happens I have to turn the computer off and then on again to get that drive to show up.
I emailed WD tech support but never got a response.
Anyone have any similar experiences? I'm thinking it might be a faulty drive?
Robert Bobson is offline   Reply With Quote
Old February 12th, 2007, 11:37 PM   #2
Are you using a firewire interface, or USB? I have some Maxtor external drives that can use either, and they tend to temporarily die (disappear from explorer) when on firewire, but don't seem to under USB operation. Also, there's a known bug in WinXP with SP2 that can affect drives and cameras -
http://digitalproducer.digitalmedian...e.jsp?id=91360
http://www.theinquirer.net/default.aspx?article=17794
If your drive is shutting down completely, it may be a different problem; mine kept running physically, just couldn't see 'em anymore... Steve
Steve Leverich is offline   Reply With Quote
Old February 13th, 2007, 05:30 AM   #3
My drive is shutting down completely - the blue circular light goes out and the drive stops spinning.
I'll try downloading the latest XP updates to see if it helps.
Thanks.
