16:9 H.264 at DVinfo.net
Old December 5th, 2006, 12:03 AM   #1
16:9 H.264
I'm trying to output a quicktime file for the web using H264 compression. I am using Premiere Pro 1.5 and everytime I render it out in this format, It always comes out 4:3. My source is 1080i HD.
I have played around with all the aspect settings and forcing the resolution. Even when I make the quicktime movie 16:9 (by either selecting the correct aspect or using square pixels and cropping the res) the actual video stays centred 4:3.
How do I output proper 16:9 from H264. I remembered I have premiere 2.0 on here too so I may try that. Cheers.
Ainslie Davies - www.dualityproductions.com
Ainslie Davies is offline   Reply With Quote
Old December 5th, 2006, 12:29 AM   #2
Ok, It's working out of PP2.0, no idea why it would only do 4:3 in H264 from PP1.5... Only bad thing is that PP2.0 crashes alot under vista while we have never had a problem with 1.5.
Actually, while i'm here. Any one got any suggestions for the best settings to use to create a relativly small but good looking quicktime for the web (of a music video)...
Old December 5th, 2006, 10:15 AM   #3
640x360 at 15fps if you want to stay under 512kbps and 640x360 at 30fps if you can afford to go to as high as 1Mbps.
Emre Safak is offline   Reply With Quote
Old December 5th, 2006, 05:06 PM   #4
And what % on the quality setting and the bandwidth?
Old December 5th, 2006, 11:57 PM   #5
I honestly do not know what to set the quality as I do not use Premiere, but I already specified the bandwidth: 512kbps is a good target for streaming, in my opinion.
