AVID Meridien System/Consumer Cameras at DVinfo.net
Old September 12th, 2006, 07:39 AM   #1
I donated an older AVID XPress System to a high school but I couldn't give them any decks. It imports from analog only using a meridien board.
I tried to hook up a consumer Mini DV camera for them, using A/V cables to RCA, hooking up the video to composite and the audio to audio input. The avid could capture the audio but not the video.
So for now I told them to digitize through firewire to Imovie, and then import to AVID. that worked. Excepts it takes a long time.
But I am thinking it is a Time Base Corrector thing, and I was wondering if it would make sense to go in fire wire through the Canopus ADVC-300 and come out analog, and then hook up to the AVID.
Any advice?
Sam Shnider is offline   Reply With Quote
Old November 19th, 2006, 10:02 PM   #2
Answer to this issue
hooked up the camera through the ADVC 110 transcoder via firewire 4 pin to six pin, and into the AVID box through composite, and it still gets some bleeding of color, but it looks fine. The camera also had an S-video out, just hidden behind the battery pack so I didn't see it at first, (model was a two year old single chip Panasonic PV-GS15.
