Thread Tools
Search this Thread
Codec questions
Not sure where to post this, but let's try here. One of the few weaknesses of the HDV codec (in my opinion) is the creation of artifacts during single frame viewing due to the interframe (GOP) compression format. DVCPRO HD avoids this by using single frame compression, but results in a large file size. As I understand it, the AVC and VC-1 codecs also use multi-frame compression. Will they also generate artifacts during single-frame viewing ? The MPEG codec is a multi-frame GOP-type frame compression codec. The XDCAM HD uses the MPEG-2MP@HL codec which is similarly multi-frame compression-based. Are there any other codecs that do not use multi-frame compression ? How about the Cineform codec ?
#2 | |
Cineform (and Cineform RAW) should be intraframe / "not multi-frame compression based".
Wavelet-based codecs like JPEG2000 and Cineform will exhibit different artifacts. you get smoothing of image detail, ringing on high contrast edges. |
Mark,
You didn't say whether your original material was progressive or interlaced. Extracting stills from interlaced video has always been problematic. I have JVC HD10 and there are insignificant artifacts on stills.
Dave |
