Ok how do I preview? at DVinfo.net
Old July 19th, 2006, 08:11 AM   #1
Ok I know yall are thinking how do you not know how to do that. But answer is I mostly did stuff for the web but now I need to preview stuff for dvd.
My problem I don't know how to do it. I thought I would be able to run both my monitors, and S video off one card but that does not work. It can only run 2 things and I need that to be both my monitors. So, whats with the fire wire output. How does this work? How do I do it?
Thanks, Jason
Jason Simpkins is offline   Reply With Quote
Old July 20th, 2006, 02:45 PM   #2
Someone give me some input please? :)
Old July 20th, 2006, 02:50 PM   #3
What video editing software are you using?
Old July 21st, 2006, 01:57 PM   #4
Sony Vegas 6. I was trying to do it through my video card but I would have to unplug on of my monitors. So, I see that it is said to do it through firewire but I have no idea how to do that and didn't find anything on it.
Old July 21st, 2006, 02:00 PM   #5
Well, you can use your camera to bridge to your TV and such, but what I use is this http://www.canopus.com/products/ADVC110/index.php This thing also is helpful when I want to do a VCR capture.
Old July 21st, 2006, 07:49 PM   #6
Ok well the bridge to the tv is what I thought. I put the camera in capture mode or whatever you call it on the GL2. Then I was expecting to see it on the camera but didn't. I wonder if this card that I has does out also. I am assuming they do.
Old July 22nd, 2006, 09:07 PM   #7
I got it working. Turned out all this time that my pci firewire card had come loose. I was thinking how hard is it to get video to the tv. But when I tried to capture it gave errors and lines on screen so then I realized it was messed up.
Thanks for the help it works great now.
