does ae change levels, saturation? at DVinfo.net
Old March 23rd, 2006, 10:16 PM   #1
this is a horizontal split screen of the raw and the tweaked footage:
http://www.geocities.com/moiseszee/A...PLITvidcap.bmp
what i did in ae is to composite that tiny thing that the door lock catches on. you can see it below the right elbow- that gray thing. this was a set and they didn't build the door with that thing so i had to add it in post.
anyway, is this a change in setup or what? coz it looks fine inside ae using my canopus video out. the low sat washed out effect is after rendering. is this an effect of transparency? a setting inside ae i don't know of?
i even changed setup in ppro and recalibrated my monitor and it still looks like that. i can color correct it but i'd rather not if i wasn't going to grade the shot anyway. besides, i'm sure some color info is lost.
any help appreciated. thanks.
Mo Zee is offline   Reply With Quote
Old March 23rd, 2006, 10:27 PM   #2
It may be a difference between studioRGB and computer RGB color spaces (in the codecs).
What editing program are you using? Do you know what codecs you are using?
Old March 23rd, 2006, 10:30 PM   #3
thanks.
another guy told me the same thing. inside premiere it's canopus. in ae, i render with microsoft dv. how do i fix this?
Old March 23rd, 2006, 10:37 PM   #4
can you use the same DV codec both times?
i.e. canopus.
Old March 23rd, 2006, 10:53 PM   #5
yup. and it worked! that was stupid.
thanks glenn
