virtual memory problem at DVinfo.net
Old March 20th, 2006, 11:13 PM   #1
Good evening,
Recently while burning a 7.2 gig project a window said i was running out of virtual memory and it may not burn properly.
I suspect i need to disable some windows programs during the process but I am not sure which or what I can actually do about the problem.
Any suggestions??? please
dale
Old March 21st, 2006, 12:33 AM   #2
Using Windows? Download Windows Defender. http://www.microsoft.com/downloads/d...DisplayLang=en
With that you can disable startup programs, keep spyware out. Pretty simple to use also. Ultimately you're going to need to upgrade your ram. (How much do you have at the moment?) But you may be able to get by with just getting rid of a lot of programs that run in the background.
Aaron Winters is offline   Reply
