Cleaning-UP Old Phonograph Recordings at DVinfo.net
Old February 8th, 2006, 09:52 AM   #1
I'm in the process of transferring some of my old 33 rpm phonographs to the digital realm and was wondering what application is best to clean up some of the "noise" that was common with records, particularly old records?
I have Vegas and the Sony audio software and AE. Any particular filter work the best for you in this regard?
Dale Nicholson is offline   Reply With Quote
Old February 8th, 2006, 10:14 AM   #2
Sony's Noise Reduction suite for Vegas and Sound Forge has a Vinyl Restoration plug-in.
Emre Safak is offline   Reply With Quote
Old February 8th, 2006, 10:45 AM   #3
http://www.bias-inc.com/
i like soundsoap....
Old February 8th, 2006, 11:22 AM   #4
SoundSoap is hot! I just looked at their product demo--thanks, Meryem!
Old February 9th, 2006, 06:51 AM   #5
Before I begin this task, a question:
All I need is a record player/amp with outputs (red and white plugs) and connect the two to my inputs of my Canopus converter and bingo!
Is that it?
Old February 12th, 2006, 11:42 AM   #6
Dale.
Cool Edit Pro 1.5 and later have good solutions for recording, cleaning up and enhancing old disk recordings. Vinyl is relatively easy. 78s offer a harder challenge as there are a variety of equalisation standards for them but as you don't seem to be likely to be going there I won't go into that.
I understand Adobe Audition represents the latest evolution of the Cool Edit software.
Old February 12th, 2006, 12:32 PM   #7
Dale.
I tried to post an update to this but it dumped and I lost it.
In short form it said - that for home consumption of the recordings, line-out from the record player or amp to line level - in on the computer;s adio card should be fine.
If you want an audiophile result, then you wll need to consider that older turntables and radiograms often used crystal cartridges which required a different equalisation and lower gain preampplifier than magnetic cartidges.
The more modern players and some older high quality players used magnetic cartridges which apparently yield a signal of more fdelity to the orginal recording than crystal (ceramic) cartridges.
Stanton and Pioneer do DJ turntables which appear similar in design. These have RCA line level pairs out, one pair for direct output from cartridge, the other for RIAA equalised output. Equalised is preferable as there is an extreme difference in hig frequency and low frequency levels otherwise which are more difficult to deal with, tha some simple sweetening and oise reduction.
These turntables also have a digtal out but what form or standard it conforms to I don't know. I also don't know if it an equalised signal or raw.
If anyone is doing recoveries from 78s I have some equalisation profiles in Cool Edit Pro 1.5 for de-RIAA, and for most of the older recordings except acoustics. I have some for Edison acoustic disks but profiles really need to be tailor made for each individual acoustic recording.
Old February 12th, 2006, 12:54 PM   #8
For 78 I use a OWL preamp that lets you dial in Turnover & Roll off. It also has rumble and HF filters. I also use a DUAL 1019 Turntable. Then the recording go into ProTools and cleaned up with Waves Restoration Bundle. Then they are archived to Mitsui gold CDs. What type of styli do you use for 78 RPM?
Glenn Davidson is offline   Reply With Quote
Old February 15th, 2006, 10:30 PM   #9
question
could a person take the audio outs and plug them into your camera and then record them onto tape, transfer to the computer and then sweeten???
gus
Old February 16th, 2006, 06:23 AM   #10
Dale.
I see no reason why not.
You record at the native sampling rate of the camcorder so less likelyhood of an error. The only downside is that sometimes, audio from MiniDV won't export to .wav files without a very aggravating sync pulse becoming embedded in the soundtrack.
If you sweeten your sound in the audio functions available in your NLE, then this problem should not emerge.
My person preference, governed by the hardware available to me is to record into the computer, sweeten the sound, then import the .wav file.
Glenn.
The stylus I use for 78s is from Ortofon. There is a specialist in Britain who custom makes styli to best perform with worn records.
I'm not a sound engineer's bootlace so don't take too much notice of my comments.
Bob Hart is offline   Reply
