An Inexperienced Question at DVinfo.net
Old December 24th, 2002, 08:29 PM   #1
It has been suggested (on this board and others), in order to save the heads, etc. of your 'good' camcorder, that you should buy an inexpensive one as an editing deck (to rewind, etc.).
My question is: If I shoot raw footage on my (3CCD) GL-1, take that tape to my cheap (1CCD) SEARS camcorder to import into PREMIERE, edit and export back to the cheap SEARS camera, do I lose significant picture quality because I ran it through a 1CCD camera, or is the original 3CCD image quality maintained?
Did I explain that right? If there is no quality loss, then why spend several hundred dollars on a mini-DV deck (unless you can afford it!), when you can buy a 1CCD camera for a couple of hundred, that will do the same thing? Of course, if you do lose image quality, why use the 'cheap' camera?
Thanks for the advice and input. Oh, and happy holidays, all.
Mark Moore
Sugar Free Productions
Mark Moore is offline   Reply With Quote
Old December 24th, 2002, 09:23 PM   #2
hi mark,
i'll try my best. using a cheaper camera. to use as a deck will not effect your footage at all. playback and recording to tape (from another source) have nothing to do with the ccd(s). so you can rest.
the reason why you see expensive dv decks and people using them is because those components are built to take the abuse a lot more than the camera. there are also some features i believe that are exclusive to the decks. i've heard too decks can usually do same tasks quicker (rewind, search/jog).
i think this is pretty on, but i can't be 100% sure seeing as i don't have a deck. i'm sure people that do can verify or correct the given info.
Matrix metering is for girls.
Matt Betea is offline   Reply With Quote
Old December 24th, 2002, 11:13 PM   #3
Sponsor: JET DV
The ONLY time you will see a difference between 3-CCD and 1-CCD cameras is when you actually record through the lens of the camera. When playing and recording via firewire to/from a computer, it is basically a file copy so you will see NO difference in an image recorded with an XL-1 whether is is played in an XL-1 or the cheapest MiniDV Camera you can find. When recording back from the computer, you will also see NO difference.
Old December 25th, 2002, 01:55 AM   #4
Thank you for the information. Then the suggestions of saving your camera by using a cheaper one for editing sounds like good advice.
I can't afford a mini-DV deck, so using a cheap camera sounds like a better option for me, saving wear and tear on the GL1.
Thanks.
Mark Moore
Old December 25th, 2002, 03:24 AM   #5
The advantage of DV decks are often component video (high quality) outputs and inputs - for interchange of betacam material or the like, and for high-quality monitoring.
Also more elaborate audio signal monitoring with meters and knobs.
Most DV decks also support DVCAM which as a format has more time-code functionality and locked audio (and a higher tapespeed so less prone to drop-outs).
Apart from that the tape transports are built more solid, so the device will probably last a bit longer - and tape transport will be faster.
That said, if your budget doesn't allow for one, getting yourself the cheapest miniDV camera with digital I/O is a great idea to prevent unneccesary wear on the heads of your main camera.
Bar3nd
www.raamw3rk.net
digital storytelling and vfx
Barend Onneweer is offline   Reply With Quote
Old December 25th, 2002, 07:31 AM   #6
Is 4-track preserved?
One other question since Mark has a GL-1, if you record in 4-track mode, will that be supported on the non-Canon deck?
Merry Christmas,
Nathan Gifford
Southern Cyclist Magazine & Productions
For quick answers try our Search!
To see me and Rob Lohman click here
Nathan Gifford is offline   Reply With Quote
Old December 25th, 2002, 02:55 PM   #7
Good question, Nathan. I never thought about the sound issues. Could I lose sound quality using a cheaper camcorder for editing?
Mark Moore
Old December 26th, 2002, 10:14 AM   #8
Sponsor: JET DV
4 track audio is a DV standard. It should pass through just fine. Works great on my deck.
Old December 26th, 2002, 07:39 PM   #9
Thanks for the info. A cheaper camera sounds like a better option for me than the expensive deck (at least for now!).
Mark Moore
Old December 26th, 2002, 10:09 PM   #10
JVC Dual mini-DV, S-VHS deck $825
Here's what's on my B&H wish list:
SR-VS30U Mini-DV/S-VHS VCR 4 Head PCM Digital Audio, Hi-Fi Stereo, Dual VCR, (Mini DVCAM Playback)
The SRVS30U Professional dual VCR incorporates the two most popular prosumer formats together in one unit, provides a complete high-performance solution for editing DV projects, mastering to S-VHS, or dubbing to or from either format. Easy integration with most NLE systems, convenient built-in editing features including automatic editing from DV to Super VHS/VHS, plus outstanding picture quality, PCM digital audio, robust tape transport mechanism. Now you can easily record and copy from DV to VHS/SVHS and visa versa. Simultaneous recording is also possible from the firewire input to both VHS/SVHS and DV.
Tom Voigt is offline   Reply
