Advice on SSD please.
Hi all, sorry, if I've posted in the wrong section.
I've this SSD enclosure order and I'm not sure what SSD to get for it. I'm replacing the hard drive in an old Sony Vaio laptop with this, if it works out. :) Can someone please link me to the exact SSD :) Thanks in advance. |
Re: Advice on SSD please.
edit: Must be an old laptop if it uses a IDE PATA connection. I'd think you'd be better with a newer laptop.
Hi thanks, the laptop still works but it’s not used at all and I just thought if I could get it up and going again with a faster c drive , some of the grandchildren might get a bit of fun out of it. It’s worth a try :). But need a link to the correct ssd :)
Thanks in advance. Last edited by Anthony McErlean; June 27th, 2020 at 04:10 AM. |
My enclosure...
The enclosure I've ordered says... Support M.2 NGFF interface SATA.... but when I look for a NGFF M.2 SSD the one I see doesn't look as if its the correct connecting socket for my enclosure, https://pcpepper.com/sata-vs-msata-v...ht-ssd-for-me/ Help me out here guys please :) Link me to the correct SSD, thanks. |
#5 |
Hi Anthony,
Realize this is not my expertise but as one who is keeping my old computers up and running I couldn't resist trying to find something that might help. Did a search for Sony Vaio SSD upgrade and came across this Crucial Sony support page. There are a LOT of Vaio models! If one of them matches what you have that may be some help. A while back I upgraded my wife's old Mac Book White circa 2006 and got one of the last SSDs available for it. All I can say is, that really put some life into the old computer! So, your plan is worth working on, hope this page might be some help: https://www.crucial.com/upgrades/sony |
#6 |
Thank you John, I'll look that up :)
Thanks |
#7 |
If your laptop takes a sata then I’d just get 2.5” ssd no enclosure or adapter should be necessary. essentially you should be swapping out a spinner drive for a solid state that’s the same physical dimensions
#8 |
Hi thank you but no, it doesn’t take a sata drive, if I had a link to the correct SSD to fit the enclosure I’ve just ordered, thank you.
#9 |
#10 |
If this is an adaptor as stated would it not accept any SSD with a sata plug? At least that's how I see it.
A little knowledge goes a long way but not long enough. |
#11 | |
Thanks Donald. Would this SSD fit the enclosure I've ordered? Last edited by Anthony McErlean; June 28th, 2020 at 04:35 AM. Reason: update |
#12 |
If it's proving difficult matching that enclosure to an SSD, if someone could link me too another 2.5'' IDE 44pin Adapter/enclosure with a compatible SSD :)
Thanks in advance, |
