Thread Tools
Search this Thread
Duration of a still in Premiere-HELP!
Hello All,
I have one frame of video that I have captured and want the duration in the timeline to last 10-15 seconds or so. When I capture the single frame and try to change the duration property it will only let me make it like 4 seconds or so. I have tried taking the 4 second clip and repeating it 4 times or so but everytime another copy of the clip comes up in the timline, I see a shift! Any suggestions? Thanks so much for your help! |
RED Code Chef
This is actually very easy. Drag the clip to the timeline and right-
click on it. Then select 'Speed' or 'Duration' to change its length. That's all there is to it. Hope this helps!
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
Thanks Rob,
Unfortunatley I have tried that, and no matter how long of a duration I enter, it on comes out to like 3-4 seconds? -SL |
How about exporting the frame as a still - changing the still import preferences to make the duration 10 seconds and importing in again?
Ross |
#5 |
You might also try exporting your three second still as an avi, then bring it back and play it at 25%, or whatever fills your time gap.
Just for the record, you are giving the image enough free space on the right to allow it to expand to the duration you set? David Hurdon |
#6 |
this may sound stupid but...
umm copy and paste the same picture together to make it longer?? kermie |
#7 |
#8 |
I did what the gentleman above suggested. I had a single shot that I wanted to last and I copied, and cut-and-pasted it side-by-side. It worked pretty good.
I must be honest and say I've never tried the 'right click' thing. I'll have to try that too.
Mark Moore Sugar Free Productions |
#9 |
Ross,
You suggestion worked perfectly! Thanks! Kermie, I already tried what you suggested and there was a flicker with a background image everytime a new copy came up in the time line! David, I tried that previously as well and as I mentioned whatever I tried it would only let me extened my 1 frame clip, to 3-4 seconds, even when I changed the speed to 1%. It seems to me that some solutions work on some people's PCs and not on others? Anyway, thanks everyone for your input! -SL |
#10 |
I'm shocked that I got something right :-) you've made my day...
Ross |
