Fujitsu PC at DVinfo.net
Old November 21st, 2011, 07:00 AM   #1
Fujitsu PC
Will the following Fujitsu work station be adequate to edit AVCHD files?
FUJITSU CELSIUS W510
Basic specifications
Genuine Windows 7 Professional 64-bit
Intel Xeon processor E3-1235, 8 MB, 3.20 GHz
Memory 8GB DDR3-1333 ECC
HDD SATA III, 7200 rpm, 1000 GB, 3.5-inch, business critical
3D: NVIDIA Quadro 2000, 1 GB, 192 cores, PCIe x16, DL-DVI-I, 2x DP
Blu-ray Disc™ Triple Writer, SATA I
Stelios
My Blog: http://steliosc.blogspot.com
"I hope for nothing, I fear nothing, I am free" Nikos Kazantzakis
Stelios Christofides is offline   Reply With Quote
Old November 21st, 2011, 09:46 AM   #2
Re: Fujitsu PC
I can tell you that a single hard disk is not enough to run any decent video editing program to anyone's satisfaction. You need at least two additional internal 7200 RPM hard disks in order to use a decent NLE properly.
Other than that, the Quadro 2000 is a waste of money: Hardware-wise, it is nothing more than an underclocked GeForce GTS 450. However, while the GTS 450 (now superceded by the GTX 550 Ti) is basically a $100 GPU, the Quadro 2000 costs $400.
Randall Leong is offline   Reply With Quote
Old November 21st, 2011, 01:46 PM   #3
Re: Fujitsu PC
Randall thanks for your reply and you are right about having two additional hard drives but I have these on my PC now that I am planning to replace. As far as the Quadro 2000 the reason that I like it is for the low noise only 26db. How noisy is the GeForce GTS 450?
stelios
