How to check integrity of back-up of video project?
I'm backing up a large amount of video files (about 240 GB) by just copying the files in Windows XP from one hard drive to another.
Is there a way to verify the integrity of all the files... some way to make sure that no video file somehow became corrupt during the transfer? I've found a program called ExactFile which compares the contents of two different folders to see that they are exactly the same, but I don't know much about the techy side of how exactly it does this and what exactly it checks. Could there be a case where a program such as this verifies that two files are exactly the same, yet the video of one file will turn out bad when attempting to play/edit it? Looking for suggestions from experienced members of the forum. Thanks! |
Re: How to check integrity of back-up of video project?
If you use the command-line and copy or xcopy you can add the /V switch to make them verify that the copy is identical to the original. There is also a command to compare files, FC (after File Compare), it compares two files, byte by byte and reports any differences found. I assume your program works in a similar way, if the to copies are not exactly the same, it will find the differences.
Thanks Frans. I know what the command line is but I'm not familiar enough with how to use it... so I'm afraid I didn't quite understand your explanation on how to test the integrity of a copied file using xcopy or /v and that stuff (which I know nothing about).
But if you think the software I have is good enough - then that's fine. I just wasn't sure - if two files are incidental byte-byte whether or not it is necessarily an indication that one is not corrupt (specifically a video file). I gather from your reply that the answer is 'yes'. :) |
#5 |
Hi,
you can also download freeware MD5Sum. This will let you calculate the 128-bit MD5 hash (i.e. checksum) of your source and copy and you can compare them. The program takes a while to run (my 5 GB video trial file took around 80% of one core of my i7 and ran for 2 mins 30 secs. If I remember correctly you can compare at the file level or at the folder level, so one calculation for each would suffice. If there was a difference found, you could then track down to eventually the different file. Once done, you could go back and check their integrity every week. This process is obviously not automated and might not suit your needs/level of effort/inclination, but I hope it helps. Cheers, Ian |
#6 |
If you use Teracopy it will do a CRC check for you after the transfer is done, just hit the Verify button and it will make sure all match
#7 |
I recommend that you consider backup software. Doing a file copy is hard as you have pointed out with the verification. I have found that routinely the file copy fails for unknown reasons in WinXP with the error message that disk is full. When your backup strategy is complicated the net result is that you neglect backups more. Dependable backups are so incredibly important for us in this business.
#8 |
I recommend not using backup software as their backups are typically a lot less convenient to restore files from. Backup software may be appropriate for special needs, but for video, plain explorer-work or command-line copy / xcopy work simpler and best.
But I agree, keep it simple and understandable, whatever backup software you choose, organise your data folders to make working with your clips and the backups as clear and straightforward as possible. |
#9 | |
I have been using "SyncBack Pro" Backup software that works - SyncBackPro and SyncBackSE for a good few years, and I couldn't imagine going back to backing up complex project folders with explorer/command line. At the very least, I second the recommendation for "TeraCopy" as good replacement for the native windows copy. |
