Editing 1080p25 with 1080i50 at DVinfo.net
Old October 2nd, 2010, 04:59 PM   #1
Hi everyone,
I need to edit both 1080p25 and 1080i50 footage together.
I'm using Adobe Premiere Pro CS5.
How would you set up a new sequence? i.e. File / New Sequence / HDV 1080p25?
What happens to 1080i50 footage if I place it into a 1080p25 sequence in Premiere Pro - does PP de-interlace the footage automatically?
thank you!
Dave Dwyer is offline   Reply With Quote
Old October 3rd, 2010, 03:40 AM   #2
Dave,
I would use 1080i50. What will happen is that the p material will show the same image on both interlaced fields and your interlaced material will remain unchanged. No need to de-interlace and throw away vertical resolution.
Old October 6th, 2010, 08:35 PM   #3
Thanks for your thoughts.
I went with 1080p sequence and published to MP4 for online viewing and the footage looks great.
I am yet to burn a DVD for viewing on a television. I may need to try your idea then.
I will update my post with the results when I can.
