White background on TV... causing harm? at DVinfo.net
Old July 28th, 2005, 12:00 PM   #1
Not sure if this is the appropriate forum for this question, but i'm putting together a tape of a professor's slide show presentation in my NLE program, and i'm wanting to cut between the video of the professor and the actual powerpoint slides (converted to high-res jpegs). The only problem is that all of the slides are black text or images on a pure white background. Will this brighr of a white cause harm to televisions? I know there are such things as "broadcast safe colors" and i plan to apply that filter to the video track, but is a screen of mostly white going to be a bad thing for a TV?
matt
Matthew Lewis is offline   Reply With Quote
Old July 28th, 2005, 05:04 PM   #2
No. The white may not display properly.
Overly bright+saturated colors aren't safe for broadcast because of the way NTSC television transmission works. Anything approaching 133IRE (composite values) will cause the transmission equipment to overheat. It may also bleed into the audio signal and cause noise in it. Anything too low will interfere with sync signals.
Old July 28th, 2005, 05:16 PM   #3
I'd just use a brightness/contrast filter to lower the white (while looking at the histogram). Sounds like an instructional video that probably won't go to broadcast, and I'd think most tv's would handle it ok (ie without damage), but equipment considerations aside, black on bright white is hard on the eyes.
There isn't really anything stopping you applying the broadcast safe filter to the track with the slides as well, but I'd go the brightness/contrast filter first.
Kyle Ringin is offline   Reply With Quote
Old August 12th, 2005, 11:16 AM   #4
Your editing program may call it something like "NTSC filter".
Enable it and it will cut the brightness levels to fit the signal. It would be more accurate to use this feature than just turning down the brightness.
Stephen Finton is offline   Reply
