WMP, VLC and QuickTime at DVinfo.net
Old August 22nd, 2010, 03:58 AM   #1
This may be a dumb question, but I would like to know what`s the problem
I have a video that I exported from Premiere and After Effects - tried both, and play it in Windows Media Player, VLC and QuickTime Player
You can see the difference in the attached picture. The picture in QuickTime and VLC looks a little bit washed out, while in WMP it looks just like in Premiere.
I exported it in H.264, but I think that`s not the problem because WMP is playing the same file, and it looks good.
Also, the same happens when I export QuickTime Animation from AE, VLC and QuickTime just doesn`t look good.
I`m using win7, and calibrated my lcd monitor if that helps..
Patrik Vale is offline   Reply With Quote
Old August 23rd, 2010, 10:31 AM   #2
There is a well-known issue with the way Quicktime translates the gamma of the image (more or less, the contrast of the mid-tones). I assume but do not know that vlc uses the qt engine for playback,but the qt translation issue is the problem....
Battle Vaughan is offline   Reply
