"Writing Script "..! at DVinfo.net
Old April 14th, 2005, 02:50 PM   #1
Anyone of you guys know of a way to make a sequence of "writing script"...as if you were writing letters with a pen. I'm after an effect like Disney has when it writes "Disney" for their logos...??!
Sorry...I haven't explained that too well...but hopefully you get the idea.
I want to "write" real time the names of the wedding party for a video; instead of just putting fonts on a screen....
Any ideas..?!
Nick Underwood is offline   Reply With Quote
Old April 14th, 2005, 03:23 PM   #2
Capt. Quirk
If I'm thinking right, all you would need is a tablet, and the right software. I used a tablet for freehand drawing with Photoshop and Illustrator, and there are several programs that allow you to write in realtime. I'm not sure of the programs names, but sports anchors use them. Try "shopping" through your favorite video magazines and catalogues.
www.SmokeWagonLeather.us
K. Forman is offline   Reply With Quote
Old April 14th, 2005, 03:38 PM   #3
Boris Graffitti has a 'write on' ability. Some of the other FX programs do to.
Richard Alvarez is offline   Reply With Quote
Old April 14th, 2005, 04:02 PM   #4
Capt. Quirk
Gee... Maybe I should play with Grafitti more often. I've had it for a couple years, and never realized what it could do.
Old April 14th, 2005, 04:29 PM   #5
Keith,
There are lots of versions of Graffitti floating out there. The limited and early versions won't do this. And frankly, since it is often bundled in with other Boris Packages (Red, FX etc.) I am trying to remember it it's a function of Graffitti or Red... the interfaces being so similar and all. I do recall going to a Boris seminar, and they did the 'handwriting' onto the screen bit.
Best stop by the boris website and look up each programs abilitites.
Old April 14th, 2005, 08:53 PM   #6
You can achieve this effect with After Effects, but it maybe only in the Pro version.
Benjamin Durin is offline   Reply With Quote
Old April 16th, 2005, 10:40 AM   #7
Thanks for the info guys....
I'm a liquid user and have never got my teeth into after effects....
Not sure if I can combine the two...but I'll try reading up on it.
Not sure if using a tablet would give me a nice smooth flowing effect that I'm after....my handwriting is appauling !!
I need a prog that will effectively "write" letters of a font...
Old April 16th, 2005, 04:40 PM   #8
Does liquid run Boris? I think so.... check out the new Graffitti 4. On boris.com
Old April 18th, 2005, 07:39 AM   #9
RED Code Chef
If the letters allow for this (the L/H can give you problems for example) you
can simply use a left-to-right transition to kinda "fake" it.
In your case it probably won't work due to the letters like the g in that sentence.
Rob Lohman, visuar@iname.com
Old April 18th, 2005, 06:04 PM   #10
Sponsor: JET DV
You might also take a look at Heroglyph. It will let you draw a path on-screen and then it can play it back using a paintbrush.
Edward Troxel is offline   Reply
