USB 2.0 or FireWire at DVinfo.net
Old April 12th, 2005, 06:09 PM   #1
USB 2.0 or FireWire
I have a 200 gigexternal drive that is both. I am running Windows XP Pro; have a 1.67 ghz athlon xp (I know it's time to upgrade); 1gig of ram; and a firewire card with 3 ports that have this hard drive, one other one, and a camera all pluged into it. Which would you run? This drive will be used to capture to. Rob brought this up and I thought I would ask the masses about it. Thanks.
Vlog On!
http://youtube.com/clintus
Clint Comer is offline   Reply With Quote
Old April 12th, 2005, 06:48 PM   #2
USB 2.0. you don't want to capture and send from the camera through the same fire wire bus. IF you have separate fire wire cards, then you could use fire wire, but if not, use the USB2.0. It technically is faster than FW, but real world tests show them to be equal.
Stefan Scherperel
SSE Productions
http://www.stefweb.net
Stefan Scherperel is offline   Reply With Quote
Old April 12th, 2005, 08:25 PM   #3
Sponsor: JET DV
I have a laptop with an external drive connected via firewire and a deck connected to the external drive via firewire. It captures and prints just fine. There's no problem having both connected via firewire - even a SINGLE firewire port. My vote is firewire.
However, either should work fine. Just connect it both ways, test it, and see which you like best.
Old April 12th, 2005, 09:21 PM   #4
Not that it's a big deal, but Firewire 400 is actually a little faster than USB 2.0 in the real-world. See http://www.pcmag.com/article2/0%2C17...44061%2C00.asp.
A quote from the article:
"Though USB 2.0 is rated at a higher throughput speed, FireWire delivered faster performance on external hard drives when connected to a desktop."
(Then of course there's FireWire 800 which is slowly trickling into the market.)
But it's all academic as both USB 2.0 and FireWire 400 hard drives are more than fast enough to capture DV video to.
Clint, we can all the recommendations we want, but as Edward said, just try it both ways and see which you like best.
Christopher Lefchik is offline   Reply With Quote
Old April 12th, 2005, 10:45 PM   #5
Well I have always done Firewire when available. But This hard drive has been giving me trouble and I was wondering if it was because it was so big. That's why I asked if I should be using USB2.0. I keep getting a Write delay error when I'm working and I have to restart the computer and sometimes I lose data. Very sucky.
Vlog On!
Old April 12th, 2005, 10:50 PM   #6
Clint,
What is the brand/model of your external HDD?
Pete Wilie is offline   Reply With Quote
Old April 13th, 2005, 01:03 AM   #7
If your hard drive uses a prolific chipset, you NEED to flash the firmware or take the drive out of the enclosue and install it internally. Eventually the file system will get corrupted and you'll need Active Undelete (PC) or similar program (i.e. PCI File Recovery?) to get your data back.
Old April 13th, 2005, 07:32 AM   #8
Sponsor: JET DV
Microsoft also has some "fixes" related to the "Delay Write Failed" error.
Old April 13th, 2005, 09:48 AM   #9
A quick search found that our very own Rob Lohman, done a small test to find out which connections worked best.
http://www.dvinfo.net/conf/showthrea...light=firewire
Cheers,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old April 13th, 2005, 10:31 AM   #10
Pete--It is a Maxtor one touch
Vlog On!
Old April 13th, 2005, 01:52 PM   #11
I've always found firewire to be slightly faster than USB, plus it's nice to use the second port on the external drive to connect to my camcorder (daisy chaining).
Firewire800 is another story....
Van Lam is offline   Reply With Quote
Old April 13th, 2005, 07:43 PM   #12
firewire is far less processor dependant.
Still, usb2 can work, but I think the best for remote work is a sata card and enclosure.
John Hartney
Elgin, Illinois USA
847.742.9321
John Hartney is offline   Reply
