DV Capture vs. MPEG-2 Capture at DVinfo.net
Old October 3rd, 2002, 12:51 PM   #1
Can anyone tell me if there are any drawbacks to capturing DV as MPEG-2? If not, it takes up a lot less HD space, but if it's too good to be true it usually is. I figure if I'm going straight to DVD anyway, what harm could come of it?
Bottom line, I don't want to sacrifice picture quality.
Any advice would be appreciated.
Alex Dunn is offline   Reply With Quote
Old October 3rd, 2002, 01:04 PM   #2
_redone_
I use MPG-2 for any DVD i plan to make. (as far as video goes.) But i usually use the DVREX MPG-2 format..not sure how your are making yours.
But yeah....to answer you question, i dont see anything wrong with MGP-2
to DVD...Ive made plenty and never ran into any problems
Adam Lawrence
eatdrink Media
Las Vegas NV
www.eatdrinkmedia.com
Adam Lawrence is offline   Reply With Quote
Old October 3rd, 2002, 01:18 PM   #3
Does it in fact take up less hard drive space?
What if I need to downgrade it to MPG-1 later?
Can you export it to tape in the MPG-2 format?
Old October 3rd, 2002, 02:16 PM   #4
Sponsor: JET DV
If you want to EDIT the video and be able to send it back to tape, DV format is better.
If you just want to STORE video, MPEG2 is fine (it just doesn't edit well)
Old October 3rd, 2002, 02:19 PM   #5
_redone_
plus for DVD, MPG-2 format seems to be the defualt format.
Adam Lawrence
eatdrink Media
Las Vegas NV
Old October 3rd, 2002, 03:57 PM   #6
Images: 10
Default??
It's more like the standard! It's required.
The only variable you got is the bitrate...9000KBPS(max)
Old October 3rd, 2002, 04:50 PM   #7
If you convert DV to MPEG-2, can you then convert back to DV format without any loss of quality?
fargogogo is offline   Reply With Quote
Old October 3rd, 2002, 11:51 PM   #8
MPEG2 is compressed. I don't believe there is anyway to uncompress it without losing video quality.
Ted Jan is offline   Reply With Quote
Old October 4th, 2002, 09:46 AM   #9
_redone_
you can still bring the bitrate up and keep image quality.
Adam Lawrence
eatdrink Media
Las Vegas NV
