changing an aspect ratio at DVinfo.net
Old October 3rd, 2002, 11:55 AM   #1
Yes, another question. Its a learning curve all this editing you know. I might have mastered Premiere in about 3 years!
If I have an aspect ratio of 16:9, or 1:78.1 I believe it is also known, how can I change it in the following ways:
1) To take the .avi file after capture, and slightly crop the 16:9 image to a 1:85.1 cinema format, so that on a widescreen TV there is a slight letterbox effect.
2) Take pure 16:9 video and make a 4:3 standard version that will display as a letterbox image on a standard TV, ie, no cropping at all, 100% of the image but zoomed out like widescreen films shown on TV with full letterboxing to retain 100% of the original image.
Can this be done in premiere? After Effects?
goldenfleece is offline   Reply With Quote
Old October 3rd, 2002, 12:54 PM   #2
_redone_
im not sure exactly what your question is....
Do you want to know if any of the above is poosible?
well.. as far option 2) i would just take in your 16:9 in premier
and do a fit to aspect ratio to 4:3. In After Effects you can just
set up a comp to 720x480 and import your 16:9 video and just scale it
down untill the width of your 16:9 image is 720 pixels.
for 1) you can do this by cropping the image in premier according to the 1:85.1 aspect....this wil create the black space on the top and bottom for you 16:9 image.
Adam Lawrence
eatdrink Media
Las Vegas NV
www.eatdrinkmedia.com
Adam Lawrence is offline   Reply With Quote
Old October 4th, 2002, 10:37 AM   #3
RED Code Chef
1. add small black bars over your footage to get 1.85. I use After Effects
2. Create a 4:3 project in Premiere. Import your 16:9 footage the timeline, right-click and select maintain aspect ratio. That will auto letterbox it to 4:3
Very easy.
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
