Help with LOGGING (Capturing) at DVinfo.net
Old January 4th, 2005, 09:39 AM   #1
I have a Sony VX2100 connected via 1394 to my Pinnacle LE 6 Pro via the Breakout Box. When I go to the capture tool, I continue to get the following problem. When I press play on the camera or in the software interface, it plays and digitizes all at the same time. It will not just play, so I can watch it and then mark in and out points. Everytime it plays it is digitizing as well. Does anyone have any input for me? It did not do this before, and I don't know if a button or setting has been changed that is resulting in this annoyance.
Trev
Trevor Dayley is offline   Reply With Quote
Old January 4th, 2005, 11:16 AM   #2
I hope I'm interpreting the question properly.
I use Edition 5.0 (just bought LE 6 but have not installed until I finish with a project) I think your problem is you are pressing the play button on the camera instead of letting LE do it for you. Open the logging tool, ID the reel etc, then hit the onscreenlay button in the logging tool, not the camera. Do your mark in - mark out, hit the log symbol (pencil) then go to next clip, mark in - mark out, hit the log symbol etc until you are done logging. Then hit the digitize button, select batch digitize and have a cup of coffee while the machine does the work. Only problem is if you have broken time code, it will get all screwed up.
Like I said - I have not worked with LE6, but I believe it is the same.
Good Luck.
Mike Cavanaugh is offline   Reply With Quote
Old January 4th, 2005, 03:07 PM   #3
I appreciate the input Mike. It use to work just like that for me as well, and then all of the sudden, even if I pressed play on the interface buttons, I was still getting it to DIGITIZE when I didnt want to.
On another forum that I frequent I posted the same question, and it appears I got the answer I was looking for. I have posted it here for everyone to read in case you encounter the same problem in the future.
"Your problem occur because you are in Rapid Capture mode.
Look at the Properties / General in the Logging Tool. Then, in the Capture section, uncheck the "Activate RapidCapture" -Sylvain P.
Thanks everyone for your help.....
Old January 5th, 2005, 08:13 AM   #4
Thanks - that will help me when I get LE 6 up and running.
