DV Storm Capture Limit
I'm just getting started with DV Storm and Premiere, and I'm reading in the instructions that I cant capture a file in avi format bigger than 2 gig. I typically shoot 30 to 60 minutes (band concerts and such) so it would be helpful to be able to load the whole thing.
I don't think this is the FAT 32 versus NTFS issue, as that would cap out at 4 gig, wouldn't it? Is there some setting I can change, or another workaround? Many thanks! Eddie
E Vaughn |
It does relate to NTFS & Fat32,
Stormedit will capture up to 4gig file, use seamless capture and it will create seamless up to 19 minutes each wjich you just drag onto timeline. Premier I beleive overcomes the limit and will capture in one file. however if your formatted as Fat32 you will have to seamless capyure in Premier also. Peter |
