Dual PC Monitor + NTSC Monitor
I am already running dual LCD monitors, but would like to add an NTSC production montior as well. The NTCS montiors over 300 lines are expensive enough already, so I was wondering if there was a way to do this WITHOUT buying a $500+ Matrox triple monitor card.
On a second note, I noticed that if I plug my TV in as a second monitor instead of my 2nd LCD, I don't get fullscreen preview monitor output from Premiere Pro 1, or Vegas 4. Vegas claims to only output a fullscreen preview window to an external monitor through a digital interface which doesn't make sense to me. Is it the same with Premiere? |
You should hook up your NTSC monitor via your deck. This is generally the best way to work. Your deck will need to be able to passthrough DV-analog.
You can substitute a camcorder for a deck. |
