changing my REAL video files to Quicktime
I am on a PC, and all of my video clips are REAL avi files, is it possible to set it up so they will be QUICKTIME clips so i can click on them and watch it through QUICKTIME??? And just because i would rather have that done. I dont like REAL.
thanks |
RED Code Chef
The problem is that almost no program can read REAL files. I once
downloaded a commercial in that format that I really wanted to keep so I converted it to QuickTime indeed. The only problem is that I can't remember which program I used for that. I'll see if I can find it again (need to remember). A quick search found RM Converter. Give that a try? (it can't convert to QuickTime I think, but it lists AVI/MPEG)
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
it's strange though, all of my video files on my coputer use to be quicktimes files, then i upgraded my windows media, so they changed to that, then i just upgraded to real10 or whatever last week, so now they are all real file clips.
RED Code Chef
No no no. I'm assuming the icons have changed?
The files themselves have NOT been changed. What Windows does is display the icon of the program associated with that file. Such files do not have an icon in themselves or something. What QuickTime and then Real have done is simply assign those files to be played back by them. When you installed both packages there were options which files you want to associate with that program. You can still change it after they have been installed by going into preferences. I'm very sure the files are untouched and still have the original extension. What you can do is to go into my computer and then choose Folder Options from the Tools menu. Go to the View tab and locate "Hide extensions for known file types" and make sure it is *NOT* on! You should really learn the basics of how Windows works and handles files and associations. If you right-click on such a file you can probably choose QuickTime or Windows Media Player under the Open With option? The default application to use for those files has just changed, that's all.
