Which is better Algolith or Twixtor at DVinfo.net
Old May 3rd, 2004, 03:02 PM   #1
Which is better Algolith or Twixtor. I have seen some footage of twixtor (30 to 24 conversion) and the image was not at all smooth. Would someone with some experience with either or both let me know which is likely to give me a smooth conversion (e.g. less or no shakes in the frames, artifacts, and a smooth 24p look). I am using the jvc hd10u hi def cam.
Dwight Flynn is offline   Reply With Quote
Old May 4th, 2004, 07:43 AM   #2
Algolith has the best quality manipulation tools, IMHO.
Are you aware their frame rate conversion plugin is only available for Shake?
Julian
Julian Luttrell is offline   Reply With Quote
Old May 4th, 2004, 07:50 AM   #3
Have you checked out MotionPerfect from Dynapel? www.dynapel.com
Mark Jefferson is offline   Reply With Quote
Old May 4th, 2004, 08:09 AM   #4
Algoligh
I am aware that algolith is only available for Shake (darn it all), but if it is truly a superior product, then it may be worth the extra step (until there is a 24p hi def cam that is reasonably priced). I have not yet tried motion perfect, but I will look into it right away.
Old May 4th, 2004, 08:34 AM   #5
2:3 pulldown and 30p to 24p
By the way isn't it possible to get the same 30p to 24p effect as these plug-ins will give using 2:3 pulldown . I am not as familiar with the technical details of frame rate conversion as some others, so please someone explain if and how my logic is faulty.
Old May 4th, 2004, 09:22 AM   #6
The likes of Algolith create intermediate frames by using advanced edge and motion detection algorithms to calculate what the frames should have looked like.
Pulldown on the other hand aproximates the new frame by taking the one nearest to it in time.
So, going 30 to 24, frame 1 should be at time 1/24th second. Algolith will generate such a frame from a combination of the 1/30th and 2/30th frames. Pulldown will use either the 1/30th frame or the 2/30th frame (I'm not sure offhand which).
Julian
Old May 4th, 2004, 01:43 PM   #7
which one is better
Thanks for the explanation, but which process is better (Algolith, or pulldowns)? Also how does motionperfect compare in this mix in terms of quality of output. I can't buy all these programs so I am looking for some guidance.
