audio sync on studio 8 at DVinfo.net
Old April 17th, 2004, 01:30 PM   #1
Hi,
I'am new to all of this. First time forum user and very new at video editing. I took up video as hobby and I really like it.
I do have some problems though. Presently using a DVD 300 camera. Two HD SATA with 1g ram. A plextor 708a burner and Pinnacle studio 8.12 with a USB studio movie box for capture.
The problem is out of sync audio and not all the audio is out of sync only towards the end of a movie that I have burned . The condition is not present on the time line only after I burn a disc and play it back.
Should I be using a Firewire instead of a USB2 capture? I have emailed Pinnacle a few months but have made little head way. Would appericate any help! By the way I have updated my burner frimwear,using Enditall2,DMA, winXP Pro Service Pk1, intel 865 Mother board,Intel 82865 Graphics , Sound Max IDA. I had my pc built by a friend that repairs pc. I hope this is enough info? Would appreciate any help.
George Di Giulio
GEORGE D
George Di Giulio is offline   Reply With Quote
Old April 22nd, 2004, 07:56 AM   #2
What you describe is a common problem with the later versions of Pinnacle Studio 8.
(After version 8.8 I believe)
From what I have heard, it only happens on "long" projects, like more than 30min.
I would recommend you to upgrade to Pinnacle Studio 9.
I upgraded from Studio 8.12 to Studio 9 a month ago, and it was absolutely worth it.
(It also support 16:9)
Old April 23rd, 2004, 10:37 AM   #3
Hi Tround,
Thanks very much for your input! I was thinking about updating to ver 9 but wanted to hear from someone who had first hand experience.
I was also told that I should use firewire instead of usb2 to capture. Are you using firewire to capture?
Thanks again for your response. George
GEORGE D
Old April 23rd, 2004, 11:48 AM   #4
Yes, I'm using firewire to capture.
That is what everyone recommend.
(I didn't know you could use usb to capture. Never heard of that.)
You can get OHCI compliant firewire/IEEE1394 capture cards for about $10-20. There are more expencive cards too, but you don't need them.
Old April 23rd, 2004, 02:01 PM   #5
Fast reply! My camera a sony uses a DVD 8cm. disc to record all video & stills and it only has a usb2 port for either & svideo in & out, also composite video in & out. I am using a usb movie box to go through to my pc. The movie box is a pinnacle box used to down load /catpure video from the camera using a usb2 port. I capture video from the camera using the svideo output to the movie box and a usb2 cable to usb2 port on pc. I was told that a firewire was a better tool.
If I use a firewire I would need a dv box from pinnacle to use firewire as the camera has no firewire connection only usb2. With the dv box I would use svideo to the box and than a firewire out to pc. I don't like using a device between the camera & pc but the only other way is to buy a different camera. Hopefully this sutdio 9 & firewire will help. Thanks for all your help!
GEORGE D
Old April 24th, 2004, 02:59 AM   #6
Well, I'm sure you can use your USB2 for capture with Studio 9 also. Capture with Studio 8 and 9 is identical as far as I know.
I would at least give it a try before switching to firewire.
Old April 24th, 2004, 04:05 PM   #7
Yes I think I will give usb2 a try before I switch to firewire. Thanks again for you help. I am going on a trip and when I get back I will up grade to ver.9.
GEORGE D
