Matrox RT.X2 and 24fps at DVinfo.net
Old July 16th, 2009, 10:28 AM   #1
Has anybody tried this?
I've got an XHA1 , but there's no native project setting in Matrox to edit in true 24P...Matrox only seems to support cameras that already have the pulldown flag in the video stream..
I'm of course, assuming the XHA1 does a true 24progessive output without any pulldown upon capture...
If it's of any use, I'm still using PPro 2.0.
Old July 16th, 2009, 01:49 PM   #2
For Premiere Pro 2.0, you will need to download the Canon 24F preset from adobe,
Adobe - Premiere Pro : For Windows : Editing presets for Canon Progressive-scan HDV cameras
I'm using Matrox 4.0 tools with CS4, that 24P preset timeline is there. I just checked. It is under Matrox - HD -> 1440x1080 -> 1440x1080 23.98fps
LA Color Pros Blog
Old July 16th, 2009, 06:54 PM   #3
Yes, thank you...It looks like i'll need to upgrade to CS4.0 with appropriate Matrox drivers..
I have the Canon Preset within CS2.0, but i don't think it's of any use without Matrox supported acceleration..
Thanks for the tip Taky...
Old July 17th, 2009, 03:07 PM   #4
Matrox Video Products
Hi Peter, I just came across your post on this user forum…one thing I like to add to Taky Cheung's reply is: If your captured footage on tape is recorded at 1440x1080 24fps, then you should select the same setting on your camera, select HDV i.link(1394) capture, and the Matrox 1440x1080p 23.98fps HDV preset to start your capturing. In order to successfully capture, the Matrox sequence must match the settings of the camera and tape.
Please contact the Matrox Technical Support Team if you are still having issues:
Matrox Video - Support - RT.X2
Best regards,
Bassel
Bassel Challah is offline   Reply With Quote
Old July 19th, 2009, 04:11 PM   #5
Now that's customer care! For those of you who don't know, Bassel is a certified Matrox Customer Service Rep who answers many questions (including mine) daily on the Matrox forums. Kudos to you for seeking out Matrox questions on other forums! That's why DVInfo is the place to go for expert video help.
"We'll fix it in post," said no videographer, EVER!
Jack Falbey is offline   Reply With Quote
Old July 19th, 2009, 04:43 PM   #6
You have to be "certified" to be a customer support rep?
LA Color Pros Blog
Taky Cheung is offline   Reply
