Windows XP at DVinfo.net
Old March 23rd, 2004, 04:37 AM   #1
Windows XP
I have WinME with Adobe Premiere6.0 and a DV500 plus board. I would like to upgrade to winxp. Will Premiere and the DV500 still work after the upgrade. Thanks all. I am currently getting the Dell message saying I need to replace the hard drive, though the drive is the second one and only one year old. Too many manual shut downs I guess.
Fred Haber is offline   Reply With Quote
Old March 23rd, 2004, 04:47 AM   #2
Hi Fred,
The DV 500 will work under XP, you just need to download the latest drivers (4.5 I think) from pinnacles web site - about 300mb ;(
Premiere 6 should also work but I suggest you upgrade to 6.5 or at least put the .02 patch on.
Cheers,
Ed
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline   Reply With Quote
Old March 23rd, 2004, 02:25 PM   #3
Thanks Ed
I guess I will try it, really appreciate the quick response, this stuff always seems to bite you in the butt.
Thanks again, Fred Haber
Old March 24th, 2004, 12:01 PM   #4
Windows versions
This is more for others finally upgrading from 95, 98, & ME to 2000 or XP.
Do it...
In the past six months I have seen at least a dozen computers that are running Windows 9X and have 128MB or greater in them. This is a problem as Windows 9X does not deal with RAM sizes greater than 64MB. Windows will report the true amount of RAM in the system but will not actually use it. What a waste.
Once you upgrade to 2000 or XP then the minimum amount of RAM you should have (especally for video work) is 512MB, and the OS will then use it. Also increase your pagefile size to a minimum of 3 times RAM and a maximum of 4096MB. This also helps performance.
Cheers,
Devlyn
Devlyn Hukowich is offline   Reply With Quote
Old March 24th, 2004, 12:22 PM   #5
Hi Fred,
Thanks - No problem.
Let us know how you get on.
Cheers,
Ed
Ed Smith
Hampshire, UK
Old March 24th, 2004, 02:13 PM   #6
Thanks Ed and Devlyn, guess I will go for it finally, sure is hair raising though.
Old March 26th, 2004, 09:26 PM   #7
Hawaiian Shirt Mogul
IMO upgrading depends on your CPU , ram , motherboard .. you have winME so it could be 4 +years old ??
i have seen some replace win98 with XP and are not happy. XP may not work correct with older hardware/chipsets ..some older machines are stuck back in PIO2,3,4 mode instead of ATA 100 .. XP takes eats up RAM & needs/eats CPU power ....
my old window 98 machine works excellent with 98 .. when i switched it out to win2K it didn't work as good as 98 .. it has 98 back in it ...
i think DELL's web site will look at your computer and tell you if it's a go for a XP upgrade ...
Don Donatello is offline   Reply With Quote
Old March 29th, 2004, 02:58 PM   #8
upgrade
Thanks for your help Don, I will try it all soon and hope for the best.
Fred Haber
