Encore file format incompatibility at DVinfo.net
Old December 28th, 2003, 03:50 AM   #1
There is one more thing: Premiere and AE also didn't accept a file...
(I have an .avi file which is 640 in width and 352 in height. Frame rate is 29 frames per second.
The problem is: I want to burn this file on a DVD disc in Adobe Encore. But Encore say: Could not import this file. Video files for this project must have a resolution of 720×576 or 704×576.
Then i decide to encode this file into a .mpg in TMPGEnc. It didn't work. I try to encode it then in WINMPG. It told me that there is problem with frames.
So. My point is: I want to make PAL 3:4 DVD inside Encore, but I can not convert a file. Problem is about size and frame rate if I understand right.
I must mention that the only program which was able to do this job was Nero Vision Express, but I was limited about making Menus etc... Nero encode the thing in a right way, that means, when I look it on a 3:4 TV, there are black bars above and below...
But I want to make it inside Encore...
Thanx for answers...
Marko)
Marko Zorec is offline   Reply With Quote
Old December 28th, 2003, 09:04 AM   #2
Could you not import the file and then resize it when you are in Encore? This now remeber is coming from a Mac person using DVD SP 2.
Sharon Fraats is offline   Reply With Quote
Old December 28th, 2003, 11:03 AM   #3
I can not import it at all in none of the applications like Encore, Premiere pro and AE...
Marko
Old December 28th, 2003, 04:49 PM   #4
After effects should accept it with no problem. 29 frames per second? Strange rate. It should either be 29.97 (drop-frame) or 30 fps if it came from a NTSC source.
Mike Rehmus
Mike Rehmus is offline   Reply
