Audio levels? at DVinfo.net
Old October 26th, 2003, 12:28 AM   #1
Audio levels?
Is there a way to set audio levels when exporting files from Premier without changing all of the settings made in the timeline? When I export my timeline from Premier 6.0 to any Windows .avi file my audio level decreases dramatically. I have to turn the volume control on the PC up all of the way to hear a descent level. Interestingly enough if I encode that same file into MPEG 2 the DVD disk has a perfect level on it. Also, when I use Premier I have to turn the volume control down as audio plays louder on it than any other program. I’m reasonably well versed in audio levels (obviously not on a PC or I would not be asking), the references I just made here to level are referring to what you hear in volume, my actual audio levels are always well mixed and at unity.
Steve
www.CorporateShow.com
Old October 26th, 2003, 11:02 AM   #2
Export all your audio to one track and then normalize it?
Glenn Chan is offline   Reply
