pixels/cm2 at DVinfo.net
Old October 13th, 2003, 07:57 PM   #1
pixels/cm2
I was wondering what everyone uses for importing images from Photoshop to Premiere. I keep pixels at 720 x 576 (PAL), but what setting for pixels/cm2 or per square inch to get best possible resolution or crispest image? or does it not matter what its set at???
Christopher Hughes is offline   Reply With Quote
Old October 13th, 2003, 09:30 PM   #2
resolution (in dpi or pixels/cm2) doesn't matter. Just look at the dimensions (heightXwidth).
Watch out for the square/non-square pixel issue. (your pictures will look distorted if you get this wrong)
Old October 13th, 2003, 10:10 PM   #3
Unless you upgrade to Photoshop CS which has a DV aspect ratio option.
Mike Rehmus
Mike Rehmus is offline   Reply
