Multiple projects/sequences in Vegas/Premiere? at DVinfo.net
Old November 6th, 2008, 07:53 PM   #1
Hi all,
Up until now i've been editing on Pinnacle Plus 10 at home, but have recently become familiar with Final Cut Pro which is what I use at University. There are a number of features on this which have persuaded me to upgrade my software at home.
The only real affordable options for me right now are Vegas and Premiere. I was wondering if either of these allow you to have several projects open at once, or to create several sequences within a project?
Since i will be using both FCP at uni and my PC-based NLE at home, which of these two programs would have the most similar layout/interface to FCP?
John
John Wiley is offline   Reply With Quote
Old November 6th, 2008, 11:04 PM   #2
Premiere Pro allows you to have multiple sequences in the same project, and you can nest sequences inside other sequences as if they are clips.
Earl R. Thurston, Stargate Connections Inc.
Made with GY-HD100: The Container Adventures: The Rescue
Earl Thurston is offline   Reply With Quote
Old November 7th, 2008, 05:42 AM   #3
Thanks for the reply,
looks like I'll get Premiere Pro then seeing as it'll be AU$250 cheaper than Vegas after the student discount.
Old November 7th, 2008, 08:15 AM   #4
The other nice thing about Premier is that you can import projects into new projects. This gives you a lot of flexibility. Can't comment on Vegas as I've never used it.
Although there might be one, I don't know of any NLEs that can have more than one project open at once. The complexity of that might actually make your processor explode. (grin)
Old November 7th, 2008, 05:27 PM   #5
Hi all,
Hi John,
You can have any number of instances of Vegas open with projects running in each instance.
You can also import projects into a project (nesting).
Mike
Mike Gunter
VideoTidbits.com
Mike Gunter is offline   Reply
