64 bit technology and 32 bit software at DVinfo.net
Old October 4th, 2008, 02:45 PM   #1
Anybody having any issues with their OS that are running 64 bit? From what I'm learning, much of the existing software is 32 bit.
I was very close to buying an new PC today(Windows Vista 64 bit) until I started talking to video folks about the problems they were encountering with 64 bit.
Any thoughts?
Older software working O.K?
Tx
Roger Lee is offline   Reply With Quote
Old October 4th, 2008, 03:46 PM   #2
Most application software will run fine using the built-in 32-bit emulation mode (or whatever they call it). Any problems will typically show up in any software that needs to load drivers or other aspects of the OS. I haven't run into any problems yet in the pure application world, but I don't run that much software either.
Phil Seastrand is offline   Reply With Quote
Old October 4th, 2008, 04:13 PM   #3
I haven't had any problems. 32-bit software runs exactly as if it were on a 32-bit machine. With a new PC bundled with 64-bit Vista, all the hardware will would fine. Only old or odd-ball hardware that you add later may be a problem. And if that means audio hardware, chances are it wouldn't work on 32-bit Vista, either.
John Miller is offline   Reply With Quote
Old October 5th, 2008, 06:13 AM   #4
Good info.
Thanks.
