Thread Tools
Search this Thread
#16 |
I've done a total re-install and the problem was the same. I'll try the different drives. Cheers.
#17 |
Different drives = Same problem
#18 |
RED Code Chef
I'm out of suggestions for now. I think there was someone else
with the same problem here. Tried to find the thread, but couldn't. Sorry I can't be of any more help.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#19 |
Will, I see the problem but I'd like a closer look at exactly what the artifacts are compared to the original frame.
Could you try putting 2 copies of the original footage on the Premiere timeline, then dissolve between them? That way, you can post the original frame, and a rendered frame, and I can compare in detail only where the artifacts show up. I know this is a lot to ask, but it would really help to have those 2 identical frames to compare, with the only difference being the artifacts. |
