What does the graphic card do? at DVinfo.net
Old May 25th, 2008, 01:37 PM   #1
Hi guys.
What's the importance of a good graphic card on a system, I always thought that the expensive cards were only for gaming? Does it affect the rendering? And the quality?
Is a 8600gt 1gb ddr2 enough? What's the most valuable (not expensive)?
wedding videography
Fellipe de Paula is offline   Reply With Quote
Old May 26th, 2008, 01:50 AM   #2
I know that there are some effect plugins for after effects that use the graphic card to speed up the rendering process but for all other encoding tasks the graphic card does nothing, then it's only the pc processor that does all the work.
So any graphics card will do for your editing system, it just depends what you intent to use it for. I would start to check what cards your editing software supports as it might use some features from specific cards to give you a better preview while editing. Also if you intend to watch blu-ray movies from your pc your card must be able to handle that.
Also see that the card has the right connectors for the screens you intend to attach. Some cards have beside a dvi connector also hdmi.
So, if you don't intent to play a game like Crysis any midrange card will do.
Old May 26th, 2008, 02:04 AM   #3
Some graphics cards have processors on board normally known as Graphics Processing Units (GPU). Some editing hardware uses the processor on-board the card to speed up effects. My Matrox Axio LE system does this and is therefore fairly picky about which cards it likes.
Not sure if any software-only solution uses the GPU for video based tasks...
Graham Risdon is offline   Reply With Quote
Old June 2nd, 2008, 10:01 AM   #4
converts energy to heat ;-)
// Laze
Sony HDR-CX130,Canon 5DMKII,i7 930@4.0, 12gb memory, 3x SSD + 2x1Tb(stripe), Geforce 480, Dual 24", Win 7 x64
Lars Siden is offline   Reply With Quote
Old June 3rd, 2008, 09:35 AM   #5
// Laze
with 100% efficiency.
Andrew J Morin is offline   Reply
