Chromatic Aberration Fixer Filter at DVinfo.net
Old April 16th, 2008, 09:48 PM   #1
On a video camera, when you go to full telephoto on a zoom lens, Chromatic Aberration can get quite evident especially with HD resolution. Using a 35mm adapter and SLR lenses, with all that glass, the image goes from worse to worser
So, in post once the footage has been captured:
Does a video-editing application filter exist? Oh please say one does... please!
Last edited by Christopher Ruffell; April 17th, 2008 at 03:16 AM. Reason: Made my question more clear..
Christopher Ruffell is offline   Reply With Quote
Old April 16th, 2008, 10:11 PM   #2
Originally Posted by Christopher Ruffell View Post
On a video camera, when you go to full telephoto on a zoom lens, Chromatic Aberration can get quite evident especially with HD resolution. Using a 35mm adapter and SLR lenses, with all that glass, the image goes from worse to worser!
Does a FCP filter exist? Oh please say one does... please!
What you are looking for is an "Achromat lens".
http://en.wikipedia.org/wiki/Achromatic_lens
http://www.cinevate.com/catalog/prod...e0d6b84d11151f
EDIT: Oops, my bad... you're looking for a plugin filter to fix CA in post, aren't you? Sorry, I'm not aware of one.
Frank Genus is offline   Reply With Quote
Old April 17th, 2008, 03:18 AM   #3
Thanks Frank, yes, in post.
Like, every single camera I've seen has a bit of CA.. its normal, but could be fixed. Photoshop has a filter, so it shouldn't be far fetched for a video app!!
Old June 22nd, 2009, 01:57 PM   #4
Has anyone a filter/suggestion to correct chromatic aberration?
The easiest and quickest solution I can come up with is using MagicBullet Looks and playing around with the chromatic aberration filter.. it seems gimmicky, but, the only quick option I can see
Old June 22nd, 2009, 02:28 PM   #5
Images: 10
There is a CA correction available in a still image plugin called PTLENS....
PTLens
If you have Photoshop Extended, you can apply this fix across a timeline.
Old June 22nd, 2009, 04:56 PM   #6
On the music video I just finished we had problems with CA from the studio cameras in the studio we used. We used the Spill Suppressor (blue) in FCP to get rid of it but it would only work if you have no other blue in the shot.
We tested a few other filters but nothing else got rid of it effectively.
John Wiley is offline   Reply
