Pinnalce Studio / Music for main Menu
Hey guy's I am not sure if this is the correct forum or not. But I am using Pinnacle Studio (Not too thrilled about it) and I am creating a simple DVD of two youth Basketball games.
On the main menu where the viewer picks where he/she wants to go I am trying to add some music. When I play the wav file outside of Pinnale the file is 1:50 in length. But when I drop it into the project it is only the 1st 20 seconds of the clip? I am wondering will I get the full version when I make the DVD? I am also wondering, will the music play and re-play the entire time until the viewer makes a chapter selection? or can the music expire? Thanks! |
When the editor does that, it is usually an error in the file that causes it. It may still play in a player, but part of the file is damaged.
The best method I have found for fixing thoses, if they can be repaired, is to run them through VirtualDub (open, then save as). If the link in VirtualDub is the same as in Studio, it has problems and you need to get it again. |
When you say the file is damaged do you mean my project of the music file that I am trying to insert?
Just the music file. The rest should be fine.
#5 | |
http://www.vimeo.com/album/6279 |
