Over Exposure at DVinfo.net
Old June 16th, 2003, 10:03 AM   #1
Over Exposure
Shot a dance recital at the weekend with my GL2. All went well except for the fact that the faces of the dancers are somewhat overexposed and difficult to make out. Is their anything I can do in post production on editing system that will make this problem as less noticeable as it is and/or go away??? I use Adobe premiere with the Matrox RTX100 software. Any help would be greatly appreciated!!!
Mike Lugton is offline   Reply With Quote
Old June 16th, 2003, 10:26 AM   #2
Try lowering the brightness and increasing the contrast. In general futz around with those settings. Color balancing might also help, though Premier's color tools are not that good. If you had something like Vegas or Final Cut Pro you could probably use color correction to fix that too.
Peter Moore is offline   Reply With Quote
Old June 16th, 2003, 05:00 PM   #3
This is a common problem with dance recitals, and although there is little you can do to fix it, I've found that lowering the NLE's white output levels a few points will keep the heads from "glowing" like they probably are now...this is essentially the same thing you often do with titles...purewhite letters will glow on most tv sets, so setting the maximum white a few points lower makes them appear white, without the glow.(there is actually a "standard" for this but I don't know it off hand).
I'm unfamiliar with premier so I can't tell you how to accomplish it there, but it would be in some sort of levels, or process amp control.
Next time with the gl2, use your zebras set at 95% or lower, and do a custom preset with setup notched upward a few points, this will help lower your overall contrast...set your exposure so that the zebras just barely show up on the dancers shoulders and foreheads. Later, adjust the gamma in your NLE to open up the shadows....(however, without convincing the lighting designer to cut his contrast by 50% or more--which will never happen, you will still struggle with contrast even with this technique.)
good luck
Barry
Barry Goyette is offline   Reply With Quote
Old June 16th, 2003, 06:08 PM   #4
Moderator
Expose for the highlights when shooting
You can also try under-exposing slightly, so that you are exposing for the highlights (faces) and everything else will usually fall into place. It's easier to adjust levels in post if your white are true and not over-exposed.
- don
DONALD BERUBE - noisybrain. Productions, LLC
Director Of Photography/ Producer/ Consultant
http://noisybrain.com/donbio.html
CREATE and NETWORK with http://www.bosfcpug.org
and also http://fcpugnetwork.org
Don Berube is offline   Reply With Quote
Old June 17th, 2003, 09:51 AM   #5
Thankyou for everyones help...much appreciated
